Company Logo Shop Now
TractorLinks.com
Re: Stronger Ford starter
RickB
11-10-2019 08:38:55
He would need a Bosch replacement for the gas starter unless he changes the ring gear. The OEM Lucas is fine on a 3 cylinder. They used the same starter on 6 cylinder engines with twice the displacement.
agjim
11-10-2019 16:51:51
 Re: Stronger Ford starter in reply to RickB, 11-10-2019 08:38:55
The one I replaced was on a 515 Ford with 3 cyl. diesel. I agree the Lucas is used on 3, 4, and 6 cylinder tractors but the Bosch turned the engine noticeable faster which cranks quicker. You will need the diesel flywheel gear but is is worth the cost and work to have a Bosch.
RickB
11-11-2019 02:47:38
 Re: Stronger Ford starter in reply to agjim, 11-10-2019 16:51:51
Itís not surprising that a new starter cranks faster than an old worn out starter. For this application Iíll save the $100 thanks.
Bern
11-11-2019 06:41:12
 Re: Stronger Ford starter in reply to RickB, 11-11-2019 02:47:38
The Bosch is most likely a gear reduction unit. I suspect that direct drive starters will go away like incandescent bulbs someday soon.
RickB
11-11-2019 13:52:44
 Re: Stronger Ford starter in reply to Bern, 11-11-2019 06:41:12
No idea what type of Bosch starter these guys are peddling. The Bosch starters used on late Powerstars, E series TLBís and LX skidsteers with Basildon engines were direct drive and no more or less durable than a Lucas. Those starters are generally more expensive.
Copyright © 1997-2020 Yesterday's Tractor Co.
