Company Logo Shop Now
TractorLinks.com
Order Ford 3000 Parts Online
Re: 1965 Ford 3000 PTO engaging problem
nashranch
11-09-2019 10:56:39
The piece on the clutch shaft has been broken and welded plus the stop bolt is broken off....
Can i pull the clutch shaft out without splitting the tractor? I'm sure the answer is NO but i thought i'd ask.
Also the clutch pedal comes up way too high. That whole left running board has been farmerized at some point.
Majorman
11-10-2019 01:57:24
 Re: 1965 Ford 3000 PTO engaging problem in reply to nashranch, 11-09-2019 10:56:39
From your picture the clutch adjustment bolt in the lever has been broken off allowing your clutch pedal too much movement and your clevis pin is in the wrong hole, it should be in the second hole for PTO work correctly.
This picture is of a Fordson Dexta but it is the same system. Note the adjustment bolt for pedal height and the two holes in the clevis.
You would need to split the tractor to get the shaft out as the clutch release bearing fork is bolte to the shaft and there is a big spring to release.
Copyright © 1997-2020 Yesterday's Tractor Co.
