Company Logo Shop Now
TractorLinks.com
Stronger Ford starter
mikewood869
11-09-2019 10:14:25
Is there a stronger starter for the 3 cylinder engines? When we put the tractor back together again we ended up using the flywheel and ring gear from the gas motor (we swapped a 3 cylinder 4000 diesel engine, the old motor was a gas 3000). The gas starter doesn't seem to crank the engine over fast enough when its a cold start (30 degrees or less)
mikewood869
11-11-2019 18:47:08
 Re: Stronger Ford starter in reply to mikewood869, 11-09-2019 10:14:25
I bought a starter for our 4400 gas over the summer and the bendix gear is now sticking.
Destroked 450
11-11-2019 17:19:34
The 5" Lucas starter used on Ford tractor since 65 has 2.7 kw output power.
The Bosch starter used on the Power Star and newer models has 3.1 kw output power.
The Bosch is no more durable than the Lucas but the extra output power helps spin the engine over faster which helps with cold weather starting.
My cousin has a 92 model 7740 with original Bosch starter, he also has a 90 model 7710 with a 5 year old Lucas.
Even thought the Bosch is older than the Lucas the Bosch spins the larger 304 engine over faster than the Lucas spins the 7710's 268.
There is a gear reduction starter that replaces the direct drive units, it also has 2.7 kw output so not sure if it would spin a engine over any faster than the Lucas or as fast as the Bosch.
Looks like it might be easier to get to the back bolt
DB Electrical shows less than $40 difference between the three.
Destroked 450
11-10-2019 10:44:16
He would still need to swap on a diesel flywheel ring, but the Bosch starter is better than the Lucas, we have both, each time a Lucas goes bad it gets replaced with a Bosch
mikewood869
11-10-2019 04:56:38
I was hoping not to split the tractor, but thank you. If I remember the diesel starter barley touched the ring gear.
Fordfarmer
11-10-2019 07:38:00
 Re: Stronger Ford starter in reply to mikewood869, 11-10-2019 04:56:38
Different tooth count, gas vs. diesel ring gears.
RickB
11-09-2019 11:38:16
Put a diesel ring gear on the gas flywheel and use a 5Ē diesel starter.
agjim
11-10-2019 04:52:29
 Re: Stronger Ford starter in reply to RickB, 11-09-2019 11:38:16
The last time I replaced a Lucas starter I put a Bosch type starter from a later model Ford on it. It was an exact fit and turned the engine a lots faster and cranked better. If you have trouble finding one contact me and I'll tell you who sells them, about 200.00 new.
RickB
11-10-2019 08:38:55
 Re: Stronger Ford starter in reply to agjim, 11-10-2019 04:52:29
He would need a Bosch replacement for the gas starter unless he changes the ring gear. The OEM Lucas is fine on a 3 cylinder. They used the same starter on 6 cylinder engines with twice the displacement.
agjim
11-10-2019 16:51:51
 Re: Stronger Ford starter in reply to RickB, 11-10-2019 08:38:55
The one I replaced was on a 515 Ford with 3 cyl. diesel. I agree the Lucas is used on 3, 4, and 6 cylinder tractors but the Bosch turned the engine noticeable faster which cranks quicker. You will need the diesel flywheel gear but is is worth the cost and work to have a Bosch.
RickB
11-11-2019 02:47:38
 Re: Stronger Ford starter in reply to agjim, 11-10-2019 16:51:51
Itís not surprising that a new starter cranks faster than an old worn out starter. For this application Iíll save the $100 thanks.
Bern
11-11-2019 06:41:12
 Re: Stronger Ford starter in reply to RickB, 11-11-2019 02:47:38
The Bosch is most likely a gear reduction unit. I suspect that direct drive starters will go away like incandescent bulbs someday soon.
RickB
11-11-2019 13:52:44
 Re: Stronger Ford starter in reply to Bern, 11-11-2019 06:41:12
No idea what type of Bosch starter these guys are peddling. The Bosch starters used on late Powerstars, E series TLBís and LX skidsteers with Basildon engines were direct drive and no more or less durable than a Lucas. Those starters are generally more expensive.
Fordfarmer
11-09-2019 16:30:19
Yep... the gasser's starter just won't cut it on a diesel. Too bad it means another split for a diesel ring gear.
nashranch
11-09-2019 11:21:48
I do have a good diesel starter with solenoid for Sale if you're interested. $50 + shipping..around 20 bucks in a large flat rate USPS box
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
