Company Logo Shop Now
TractorLinks.com
Order Ford 2000 Parts Online
Ford 2000 3cyl diesel valve clerance
Dirk Pitt
11-09-2019 05:48:56
Hi. I need values for valve clerances on Ford 2000 1965, 3cyl diesel. Been all over the internet and cant find it. Thanks.
Dirk Pitt
11-10-2019 08:20:31
 Re: Ford 2000 3cyl diesel valve clerance in reply to Dirk Pitt, 11-09-2019 05:48:56
Ok. Thanks for help!
Destroked 450
11-10-2019 08:09:31
Same setting for all Ford 3 cylinder, 65/later 4 cylinder and 6 cylinder engines
Dirk Pitt
11-10-2019 07:58:09
Thank you guys!
I have set it to .41mm intake and .48mm exhaust on cold engine.
Can this measures be applied on Ford 4000, 1966, 3 cyl diesel?
Destroked 450
11-09-2019 07:00:42
Intake 0.36 - 0.41 mm
Exhaust 0.43 - 0.48 mm
I set mine to the max setting cold.
hurleyjd
11-09-2019 06:53:16
Inchs to MM
Dirk Pitt
11-09-2019 06:21:12
In millimeters please if you have the informatio because Im from Europe.
Tom in TN
11-09-2019 06:28:16
 Re: Ford 2000 3cyl diesel valve clerance in reply to Dirk Pitt, 11-09-2019 06:21:12
Dirk,
My Ford 2000 Service Manual says that .017 inches is the equivalent of 43 mm, and that .019 inches is the equivalent of 48 mm. Knowing nothing about metric measurements, I can't say if that sounds reasonable or not.
Tom in TN
Tom in TN
11-09-2019 08:36:40
 Re: Ford 2000 3cyl diesel valve clerance in reply to Tom in TN, 11-09-2019 06:28:16
Ah, Yes. I just looked at my manual again and saw that it should be .43 and .48 millimeters NOT just plain 43 and 48.
Sorry about that.
Tom in TN
Tom in TN
11-09-2019 06:18:47
Dirk,
According to my I&T Shop Manual, the cold adjustment is .017 for intake valves and .021 for exhaust valves. At operating temperature, intake valves are .015 and .018 for exhaust valves.
The manual has two pictures showing which valves can be adjusted at TDC on the compression stroke of the number one piston and which valves can be adjusted at TDC of the number one piston on the exhaust stroke. I'd send you a picture of the picture, but I have no idea how to do that.
No distinction is made in the manual for gasoline versus diesel engines.
Good luck,
Tom in TN
sunbeam
11-09-2019 06:07:01
15 intake 18 exhaust.warm
hurleyjd
11-09-2019 06:20:30
 Re: Ford 2000 3cyl diesel valve clerance in reply to sunbeam, 11-09-2019 06:07:01
Pretty gap there.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
