Company Logo Shop Now
TractorLinks.com
Re: Genesis air ride seat
Larry NCKS
11-09-2019 02:16:39
I do not hear air. I'm wondering if there's a link between the motor and compressor. It was pumping and totally quit, like something locked up. Then a day or two two later the motor would run again but no air.
To be able to work on this thing or even see the compressor, I think I need to get it lifted somehow without the benefit of air.
RickB
11-09-2019 17:07:07
 Re: Genesis air ride seat in reply to Larry NCKS, 11-09-2019 02:16:39
Grab ahold of it and raise the seat until the scissors is fully extended. Have someone stick a 2x4 under the front corner of the seat pan. Unless there is a small pinhole in an air tube that causes a high velocity leak, you probably won’t hear air over the buzz of the compressor. If the compressor runs you probably have a damaged or disconnected line or a failed bag.
welding man
11-09-2019 05:26:37
I am working on an air seat in a JD 6200 now . The new compressor and lines were over $450.00,plus the things are a pain to work on. Good Luck
Copyright © 1997-2020 Yesterday's Tractor Co.
