Company Logo Shop Now
Genesis air ride seat
Larry NCKS
11-08-2019 16:26:18
won't air up. Motor runs but no air. Seat is sitting all the way down. What's the best way to tackle this issue? Thanks!
Larry NCKS
11-11-2019 17:41:32
 Re: Genesis air ride seat in reply to Larry NCKS, 11-08-2019 16:26:18
Mine doesn't pump air whether I'm in it or not.
Don't think it's merely a cold weather issue.
Texasmark1
11-11-2019 14:06:37
Cold weather and mine, including new ones right out of the box, bleed down over time allowing the seat to bottom out and don't want to air up in the winter. Solution is to get out of the seat and pump it up to full up position, then adding more air, testing the tension and when firm, then sit on it and adjust accordingly. Once it warms up it works normal. I have been all over my original, had it out of the tractor, on the work bench, soapy water testing and all and no luck. I bought a new one, different brand but parts seemed to be of the same design...like a universal pumping system, just different frame, size, and bolt pattern, and was surprised to see a new one acting the same way telling me that if it has a leak, it's going to take submerging in a liquid which is impossible......I think!
RickB
11-09-2019 11:39:51
Pull the seat all the way up and block it. Drop the bellows and start investigating,
Larry NCKS
11-09-2019 02:16:39
I do not hear air. I'm wondering if there's a link between the motor and compressor. It was pumping and totally quit, like something locked up. Then a day or two two later the motor would run again but no air.
To be able to work on this thing or even see the compressor, I think I need to get it lifted somehow without the benefit of air.
RickB
11-09-2019 17:07:07
 Re: Genesis air ride seat in reply to Larry NCKS, 11-09-2019 02:16:39
Grab ahold of it and raise the seat until the scissors is fully extended. Have someone stick a 2x4 under the front corner of the seat pan. Unless there is a small pinhole in an air tube that causes a high velocity leak, you probably won’t hear air over the buzz of the compressor. If the compressor runs you probably have a damaged or disconnected line or a failed bag.
welding man
11-09-2019 05:26:37
I am working on an air seat in a JD 6200 now . The new compressor and lines were over $450.00,plus the things are a pain to work on. Good Luck
Bern
11-08-2019 16:45:18
A beanbag?
I don't know - I've never worked on one. Do you hear the motor passing air? If so, it could be as simple as a broken hose. Myself, I'd pull the curtain down and start looking.
showcrop
11-08-2019 16:30:46
Just leave it all the way down and pretend that you are driving a Petercar.
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: Oliver model 101 1-16 rope trip plow on steel. Includes new share/point and great mouldboard. 300 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
