Company Logo Shop Now
TractorLinks.com
Re: Ford baler motor
Sean in PA
11-08-2019 03:15:57
If you get the casting number off the right side of the block we can probably tell you if it's a 172 or 134. The 172 was used in the the 8xx, 9xx and 4000 series 4 cylinder tractors and the 134 was used in the 5xx,6xx,7xx and 2000 series, but they are direct bolt-in replacements for each other so a 172 will fit in your 2000 just fine. If you put a 172 into a 2000 then there is the potential for applying to much power to the rear axle and damaging the differential, but on a backhoe/loader tractor that shouldn't be an issue.
daverd4
11-08-2019 05:59:56
 Re: Ford baler motor in reply to Sean in PA, 11-08-2019 03:15:57
Thanks the owner is going down to make sure what it is this weekend. Sounds like its a little ways from his house will let you know then.
Copyright © 1997-2020 Yesterday's Tractor Co.
