Ford Tractors Discussion Forum |
Re: Starter Switch question
Author |
[Modern View] |
Sean in PA
11-08-2019 03:09:15
I'm not familiar with that new of a model. In earlier diesel models, once the engine is started the only way to shut it off was to pull out the handle that kills the engine, as that is the only way to stop the flow of fuel to the injector pump, and there is nothing electrical required to keep that style of engine running once it has been started. Does yours normally turn off when you turn the key off, or does it have a separate kill handle that yu pull like the earlier ones? If it turns off with the key that means that there is an electrically controlled solenoid valve that stops the fuel flow to kill the engine, and I would be looking there, most likely the wire from the "Run" position on the key switch isn't getting voltage to the solenoid or the key switch itself has gone bad.
If it has the earlier style handle that you pull to kill the engine then the key switch should normally have nothing to do with killing the engine once the engine has started. The only thing I can think of might be that the bendix on the starter is stuck with the starter gear always engaged with the ring gear, and so when you let the key drop back from "Start" to "Run" the drag of the starter on the engine causes it to die, but that is only a guess.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Fast Shipping! Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ] |
Home
| Forums
Copyright © 1997-2019 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
