Company Logo Shop Now
TractorLinks.com
Re: Ford baler motor
Fordfarmer
11-07-2019 20:01:16
Unless it's got a belt driven governor, the governor should be the same as in a tractor. I took a 134 out of an OMC swather and put it in a 4-cylinder 2000. Straight bolt in. Only difference I found was the industrial engine had a fuel pump, while the tractors are gravity fed. I just put a block off plate over the pump opening.
Leroy
11-09-2019 12:15:31
 Re: Ford baler motor in reply to Fordfarmer, 11-07-2019 20:01:16
I don't know that baler but I question the govener being same as on a tractor, I am basing my guess on the New Holand 66 baler we had. On that the 2 cylinder engine had a set fixed operating speed or idle, that engine was used in some small tractors as well and for that they had a veriable speed governer. Then the John Deere 2010 tractor and the No. 45 combine used same engine but tracotr had variable speed verses combine fixed operating speed or idle. So on that baler doers it have a fixed operating speed that would only run baler at a PTO speed or could you run it at half speed? If engine runs should be very easy to tell what govener it has if you can run baler at only idle or wide open or any speed in between. Just questioning because of the difference in the way my too implements were made as for govener.
daverd4
11-07-2019 20:06:15
Thanks that's what it's going in is a 1964 2000 loader backhoe
Copyright © 1997-2020 Yesterday's Tractor Co.
