Company Logo Shop Now
TractorLinks.com
Order Ford 600 Parts Online
Ford 600 engine front cover
moday
11-07-2019 11:38:19
Front cover has a crack. It appears to be cast, but is that iron or aluminum? I donít think cast aluminum was common in 50ís but any suggestion on fix? Probably braze it but what rod?
Sean in PA
11-08-2019 08:51:12
 Re: Ford 600 engine front cover in reply to moday, 11-07-2019 11:38:19
A 600 has a 134 ci engine. I'm guessing 132 was a typo? The front cover from any 134, 144 or 172 engine from any 1955-1964 tractor will fit. The part number is the same across all gasoline and diesel engines from that time frame.
moday
11-08-2019 09:31:01
 Re: Ford 600 engine front cover in reply to Sean in PA, 11-08-2019 08:51:12
Thanks.....I knew it was close. 134 CI, my bad
Fordfarmer
11-07-2019 14:08:09
I have a front cover from one with a windowed block that I parted out. $15 + shipping, if you're interested.
moday
11-08-2019 05:18:30
 Re: Ford 600 engine front cover in reply to Fordfarmer, 11-07-2019 14:08:09
Ford Farmer, I left you a message or tell me a better way to contact you. I want to make sure that the f/c will work on my tractor. maybe only one out there for a 132 CI engine? thanks, MO
moday
11-07-2019 13:40:32
Looks like J.B. weld was on it but came off when I cleaned the cover. Any brazing options?
sotxbill
11-07-2019 13:12:55
try the magnet test??
usually a cheap pot metal. pending on where, you could sand it, clean it, clean it, clean it and then jb weld it. I have had very good success doing that in most cases only where I could sand it and clean it. Otherwise it wont work well at all if oily or dirty.
moday
11-07-2019 11:53:03
Sorry I posted twice....used my phone, Oops.
One can be removed if the moderator can do that. thank you!
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
