Governor ring weight
BambiBasher
New User
Went to reassemble my DBG pump and a weight had fallen and hit the floor. It broke the tip off that sits under the thrust washer. I m striking out with trying to find a replacement. Does anyone have one or know where to get one? Local NH says no longer serviced. I m at a complete loss and I need to get my tractor going again.
See if this works. The one on the right is a good one still.
(quoted from post at 14:42:58 11/06/19) The one in your hand has the TOP broken off, that's NOT the end that goes under the thrust washer. I have that weight on hand, E-mail is [email protected] if you would like to get in contact.
I ll be sending your an email immediately sir. Thank you!
