shopforman
New User
I've come to wits end and need help. I am working on a three cylinder Ford diesel engine. The owner brought it to my shop for him to change the engine oil and filter. He did that and we discovered a anti freeze leak at a hose, tightened the clamp and fixed that. When checking the level of anti freeze we discovered it was full of motor oil. I thought it had to be the oil cooler so we bypassed it flushed the system and thought it was done. Next day I started the engine to get the new anti freeze moved around so I could check the protection level. I had to add anti freeze as it was low. I also checked the oil level and found a crank case full of anti freeze. Now we had run the engine the day before and the oil level was check several times, all was okay.
Does anyone have any thoughts on how this could happen?
