Company Logo Shop Now
TractorLinks.com
Re: Engine swap
kirk-nj
11-06-2019 00:18:08
I donít see a problem with it. I think I remember the mounting bracket for the PS pump was different in the Row crop but donít know if it will be a problem. You will have to use the upper holes for the tin and longer throttle lever cause the diesel tank is bigger. You need electric system with it along with the bigger battery tray. And donít smash your fingers like I did when mounting the HD flywheel. Other than that canít think of anything off the top of my head should be pretty straight forward.
daverd4
11-06-2019 06:52:55
 Re: Engine swap in reply to kirk-nj, 11-06-2019 00:18:08
Thanks So I should have all the parts from the 981. Not sure I understand about the upper holes in the tin? Will the flywheel and clutch off the 2000 gas bolt up to the diesel motor?
kirk-nj
11-06-2019 11:22:40
 Re: Engine swap in reply to daverd4, 11-06-2019 06:52:55
As long as both are 4cyl you should have no problem. Upper holes in axle carrier and on steering housing. Put electric system on with the diesel Itís 12volt
Al Baker(pumpman)
11-06-2019 11:02:57
Mr. Daverd4, Would you consider selling parts from 981 after you are done with the engine swap? I am starting on a 64 4000 crop SOS and am sure I will need a part or two. Al 231/757/0064
daverd4
11-07-2019 06:20:34
 Re: Engine swap in reply to Al Baker(pumpman), 11-06-2019 11:02:57
If I buy it I'll give you a call
Copyright © 1997-2020 Yesterday's Tractor Co.
