Robert (ID)
ok anyone got a special witch's brew for getting rings to pop off a piston..
On this 268 i'm working over, piston# 4 has the second ring stuck in the piston... the top ring and the oil ring came out fine... so any suggestions on getting this final ring out??
Also is it common for this engine to only have 2 compression rings?? Every listing I look at lists 3 compression rings!
thanks guys
thanks guys
