Company Logo Shop Now
TractorLinks.com
Re: Transmission Case Interchangeability
Sean in PA
11-04-2019 17:24:00
I assume that your 4000 with the S-O-S is the later 3 cylinder 4000, otherwise no tractor made after 1964 will have a transmission that will swap in.
It's best to find a complete rear half of a tractor that is known to be good, as the 3 cylinder 4000 S-O-S tractors had a differential with a different gear ratio (6.67:1) than the ones with the manual transmission (3.50:1), so the tractor will be too fast with a manual transmission if you simply swap the transmission without swapping the differential as well. Be sure to get everything from the flywheel on back from the donor tractor, as that will guarantee everything works together.
Copyright © 1997-2020 Yesterday's Tractor Co.
