Just purchased a Ford 5610 with cab.
The 3PH is like grandpa on viagara, they are up, but won't go down at all.
There was no oil in the rear end when I first got the tractor, ended up putting a pail and a half of oil in before it finally registered on the dipstick.
Found a leak in the front where the hydraulic hoses go into the oil cooler, fixed that issue, however the 3PH is still stuck in the up position.
Possible air lock? If so, how to bleed it?
