Company Logo Shop Now
TractorLinks.com
Re: need 4cyl info..
Bern
11-03-2019 15:17:30
August of 1987 is when the switch was made from 1/2 to 9/16" head bolts. Note two choices for #7 head bolts at the link below.
I'm not aware of any casting number changes to the block when they went to the bigger head bolts, although there very well may be. I can tell externally which size head bolts it has by looking at the size of the hex head. If it takes a 7/8" socket, it's a 9/16" bolt.
Robert (ID)
11-03-2019 16:47:26
 Re: need 4cyl info.. in reply to Bern, 11-03-2019 15:17:30
Thanks Bern
Was there a casting number change for the later model head??
for $900 i may get brave and put my old head on the mill and drill out the holes...
my block has these numbers stamped on the right hand pan rail
F438883 3m14 87840243
Bern
11-03-2019 17:29:39
 Re: need 4cyl info.. in reply to Robert (ID), 11-03-2019 16:47:26
The 87840243 is a NH number, so that would be new enough to use the 9/16" bolts.
I'm sure the casting numbers on the head changed, but I do not have that specific info. That's really getting into the weeds.
I would certainly consider drilling out the holes if it were mine. You wouldn't have to remove much to get the 9/16" bolts to pass through because the existing holes are already quite a bit bigger than 1/2".
Robert (ID)
11-03-2019 19:30:54
 Re: need 4cyl info.. in reply to Bern, 11-03-2019 17:29:39
thanks Bern
Copyright © 1997-2020 Yesterday's Tractor Co.
