Company Logo Shop Now
TractorLinks.com
Order Ford 861 Parts Online
Ford 861 Hydraulic valve operation?
TSwalla
11-01-2019 14:17:55
I recently purchased a Ford 861 that has a hydraulic control valve on it. When I push the lever in one direction it pressurizes one of the hoses, when I push it in the other direction it doesn't do anything. Can anyone tell me what the knob (arrow pointing to it) is supposed to do?
[/img]
Destroked 450
11-03-2019 07:34:08
 Re: Ford 861 Hydraulic valve operation? in reply to TSwalla, 11-01-2019 14:17:55
That knob is the float control valve, it must be turned completely in for double action to work
TSwalla
11-03-2019 06:25:38
Sean in PA I'll give that a try, thanks for the suggestion.
Sean in PA
11-03-2019 05:36:52
I'm not familiar with that particular valve either, but in your first picture I see a small screw near the large black knob with a few threads exposed. That might be the screw that switches it from single acting to double acting. Try screwing that all of the way in to see if it switches to double acting. The large knob might be a flow control valve that controls how fast the fluid flows.
TSwalla
11-02-2019 17:20:33
I tried turning the know in fully and backing it out to the point that it would not leak, it made no difference, still acts like a single action valve.
TSwalla
11-02-2019 12:46:56
Can you tell me if the adjustment know should be turned all the way in or out to change from single to dual activation?
Ultradog MN
11-02-2019 22:54:27
 Re: Ford 861 Hydraulic valve operation? in reply to TSwalla, 11-02-2019 12:46:56
I can't help on which way to turn the knob. My tractor is still in a hundred pieces and I've not used the valve yet.
Ultradog MN
11-02-2019 10:49:20
That valve is newer than your tractor.
My 66 model had that style from the factory.
Not that that matters. The same valve will fit Fords from 1955 till at least 1981.
TSwalla
11-01-2019 20:32:48
Thanks, I'll give that a try.
Here's another view of that valve. I believe it's an OEM valve.
Royse
11-01-2019 17:40:14
I'm not familiar with that particular valve, but on other valves, a
screw in that location changes it from single acting to dual acting.
You might try turning it all the way in or out to see if it changes.
Welcome to the forums!
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
