I appreciate the help you all have given me so far when we figured out my 2910 is an early production model that does not utilize the dash clusters that are sold aftermarket now. I was able to get a new tach cable, new tach driveshaft cable, and disassembled my old tach and got it all working today. That leads me to my next questions if any of you all could help. The bulbs were physically pulled out of the dash cluster when I opened the dash up due to varmints having a condo packed in there. I know what two bulbs are for my dash illumination lights, but I need help with the other three bulbs. They all light up and seem to work, but I am unsure which go where. I know I do not have a flasher bulb, but believe I have Amp/Air Filter/Oil Pressure. When I turn the key on those three illuminate immediately. When I turn the key to crank the tractor all three go out and stay out once started. Now if I crank the tractor for 5-10 seconds with the fuel shutoff two stay out and after a few seconds of releasing the key a single bulb comes back on. I think that is the amp/charging bulb, but also not sure if it is the oil pressure bulb. I am thinking a oil pressure light should maybe also come on also, but then again I am not sure. I have purchased a service manual on CD-ROM, but it is a copy of a copy and hard to read and follow in places and I cannot justify $350 for a Jensales reprint.
Thank you for any help you can send my way!
