Company Logo Shop Now
TractorLinks.com
Re: 2910 Diesel Tach and Dash Cluster Again
Sean in PA
10-31-2019 19:08:41
Pull the wires at the senders, one-at-a-time and see which light does not come on when you first turn the key on. Oil pressure sender is on the side of the block near the oil filter. Air flow warning sender should be in the tube connected to the intake manifold. I'm not sure where the charge warning light is connected on that model, but if you can figure out the other two then it should be the third one.
Bouncer
10-31-2019 19:30:38
 Re: 2910 Diesel Tach and Dash Cluster Again in reply to Sean in PA, 10-31-2019 19:08:41
It's not necessarily that simple, I don't think. They work off diodes and are tied in by some sequential order off of each other. The oil pressure sender is nothing more than a single wire switch that gets made and causes a ground/no ground situation, the air cleaner is a two wire switch that I assume is probably some sort of diaphragm design, and that leaves the gen light tied in. Diagnostics is not the problem nor is the know how of 12v wiring systems, the biggest issue is not having a clear wiring diagram to be able to read from. I kind of assume Ford used the same or very near the same wire harness on it's diesel tractors from the 00 series on up into the 10 series. I just thought someone may have ran across this before and had a fairly easy way to distinguish between the three.
Copyright © 1997-2020 Yesterday's Tractor Co.
