Company Logo Shop Now
TractorLinks.com
Order Ford 600 Parts Online
7600 pto stops when warm
Youngin
10-31-2019 13:47:09
Have a 7600 that will spin brush hog but after it warms it will not. It has dual power. Where should I look? Thanks
Bern
10-31-2019 19:41:54
 Re: 7600 pto stops when warm in reply to Youngin, 10-31-2019 13:47:09
You'll need to make up a tee fitting for the low pressure circuit to check the pressure. I made one of my own by taking an existing dual power tee and tapping it for 1/8" pipe thread.
Once you have the gauge installed, check pressures with the PTO on versus off, and with the dual power in low versus high. Look for a large drop in pressure while shifting. I suspect that the problem is in the high range of your dual power. That's the usual culprit.
sotxbill
10-31-2019 17:08:12
The pto and dual power run off the low pressure pump that is part of the transmission pump. So not to confuse with mega flow pumps on other models.
Would get service manual and do the tests to see where the problem is located. Could be dual power, pto, or worn out pump. Manual show how to tap into the circuit at the pump. Assuming that the 3 pt lift is still working correctly when this happens. Would pressure test the high pressure side as well.
Shaun Wallace
10-31-2019 14:35:12
Either worn piggy back pump ,worn plates,leaking pto piston seals ,leaking DP seals . Betting on DP seals.
Copyright © 1997-2020 Yesterday's Tractor Co.
