601 hydraulic pump seal installtion
Dale2
I am putting a new seal in the nose of a 601 piston type hydraulic pump and am not sure what side goes where. On e side of the seal has the metal flange on ti and the other side does not. It is a double lip seal that seals both ways but I feel there is a right way to put it in the housing. Does anyone know which way is correct. Also this housing has some gouges in it wher the seal sets. Can I use silicon gasket sealer and seal those as I install the seal or would there be a better product to use?
thanks
Dale
