7600 Rear main wiring harness
dbeam
I found out from an earlier post that I need the rear main wiring harness (needing the harness that goes to the key switch) for a ford 7600 with out a cab, I was getting ready to order it thinking I had already found them before but now am having trouble. Is this the right one C9NN14A103C (the one sold by this sight) I know it says front but it is the only on they have listed. Are do I need both of these?
http://www.crosscreektractor.com/default.aspx?page=item%20detail&itemcode=C9NN14A103C
http://www.crosscreektractor.com/default.aspx?page=item%20detail&itemcode=C9NN14N104B
If anyone can point me in the right direction would be much appreciated. Thanks.
If those pictures represent what the actual harness looks like, I don't like what I see. If you only need
one harness, it certainly wont plug into the other side of the factory harness.
This is what I came up with for a rear main harness. Your choice depends on what year your tractor is.
If you have the budget, then use: Agri-Services Wiring Harness Specialists, 716-937-6618. I'm very guilty of buying those low cost parts on-line that someone
claims is an OEM equal, but end up a bit upset with the quality. Once heard this: "poor quality remains long after the sweetness of low price is forgotten"
Just wanted to let everyone know that I called on those harnesses and they told me those were for English built 7600s that are fused (Didn't see fuses on mine and they told me it is probably not English). After I sat and looked at it I realized that none of the wires were being used now anyways except the alt wire (alt had been replaced with a single wire version) and the wiring is pretty simple anyways. I just removed all exposed wiring and heat shrank any cut wiring and loomed everything. Custom wired the ignition switch tapping straight into hot off of starter (fused it there). Even wired back in that heater thing (I think it ignites diesel in intake?) so it cuts on when you turn the key part way.
