Company Logo Shop Now
TractorLinks.com
Order Ford 600 Parts Online
7600 hydraulic fluid type and capacity.
dbeam
10-29-2019 18:44:32
Getting ready to changed hydraulic fluid and filter on a 76 ford 7600. Anyone know what type and how much? Transmission number is 5L21B and HYD PUMP is 5M22B if that helps any.
Thanks.
dbeam
11-03-2019 17:59:19
 Re: 7600 hydraulic fluid type and capacity. in reply to dbeam, 10-29-2019 18:44:32
Quoting Removed, click Modern View to see Thanks very helpful.
dbeam
11-03-2019 17:59:06
sotxbill
10-30-2019 18:17:38
My operators manual call for ford 7700 to use....
M2C53A Hydraulic fluids in the transmission/rear end..
M2c41a in the power steering
This would be the row crop version of your 7600.
ironically the 5000 owners manual calls for
m2c53a for hydraulic and m2c41a for power steering.
The newer 7710 manual calls for m2c134 oil for hydraulics and m2c41a oil for power steering. The m2c134 has NO letters after it.
The even newer 7710 II manual calls for m2c134b or m2c159a, or m2c86-b hydraulic oils and m2c41b oil for power steering.
dbeam
10-30-2019 10:52:11
Quoting Removed, click Modern View to see Thanks alot I'll be getting the fluid together. Do you know where the drain plugs are/how many and do I just feel it up at the top of the transmission?
Fordfarmer
10-30-2019 11:02:16
 Re: 7600 hydraulic fluid type and capacity. in reply to dbeam, 10-30-2019 10:52:11
Three drain plugs.
Can be refilled either at the top of the transmission or at the top of the lift cover, just behind the seat and slightly right of center. With the common sump, use whichever is easier. My 7600 has a cab, so I use the fill plug on the lift cover.
Fordfarmer
10-30-2019 10:05:27
Sean is right - multiple drain plugs, but one big common sump. Takes 60 quarts (15 gallons) of UTF that meets or exceeds (not just "compatible with ") New Holland spec 134D hydraulic/transmission oil. 56 quarts, if it's a 540 only pto... but every 7600 I've come across has been 540/1000.
Sean in PA
10-30-2019 04:11:35
Those numbers are just date codes for wen they were assembled. The transmission was assembled on November 21 1975 and the Hydraulic Pump on December 22 1975, both during the day shift.
I believe that the transmission and rear axle/hydraulic sump is one big common sump, even though there may be two or even 3 drain plugs underneath. I don't have a reference for that model's capacities, but exact capacities might depend on whether it has dual power and/or load monitor.
Copyright © 1997-2020 Yesterday's Tractor Co.
