I'm scratching my head so will start from beginning. Have
600 gas 6 volt positive ground with gen. Sometime ago the starter
push starter on trans went bad so I put in a push button starter in inst.
panel. Later tractor started acting up so replaced coil and plugs
and found that my keyed switch (on and off only) was faulty.
I replaced the keyed switch with an on and off flip switch. Now the
only way I can get it to start is ground the generator wire which
makes voltage reg go to minus 10 and thus after 2 hrs dead battery,
but tractor will continue to run (just will not restart) unless jumped.
I know gen wire must go somewhere else just don't know where. Any suggestions
appreciated. It's for sure I am no wiring guru.
