Company Logo Shop Now
TractorLinks.com
Order Ford 4000 Parts Online
Re: Ford 4000 gasoline 1972 running rough
Deutz Lover
10-27-2019 22:12:53
Sometimes the choke or throttle butterfly shaft/or bushing gets worn and allows air in to upset the mixture. If the float and everything else is okay you can temporarily check this by dobbing heavy grease (ear swab)on the both sides of the shaft while it is running to seal the leak if that is what is going on. The tractor is 35 years old.
An alternative is to take a propane torch, turn the propane on and run the unlit head around the carburetor and intake gaskets to see if it affects the idling engine.(raise the idle enough to keep the engine running.) This is a check for gasket leaks, throttle leaks, and warped intake manifolds.
Copyright © 1997-2020 Yesterday's Tractor Co.
