Company Logo Shop Now
TractorLinks.com
Order Ford NAA Parts Online
Re: Jubilee fluids
showcrop
10-27-2019 04:53:35
In a Jubilee a lot depends on how you use it. Your jube has no clutch packs or wet brakes that need special oil additives, so it will do just fine on the plain hydraulic oil as miner09 said. If you decide to go with the modern UTF with the additives, it is good for your jube also, provided that it does not get laden with moisture. The additives tend to absorb moisture from the atmosphere and the oil will turn milky. If you are working it hard occasionally the oil will get hot enough to drive the moisture out. Oil with moisture in it is bad for your hydraulic system.
Copyright © 1997-2020 Yesterday's Tractor Co.
