Company Logo Shop Now
TractorLinks.com
Order Ford 2000 Parts Online
Industrial 2000
daverd4
10-26-2019 21:08:56
Just saved a Ford 2000 Ind. Loader Backhoe have no ideal of the serial number could someone decode this for me pic included. Thanks
Sean in PA
10-30-2019 08:45:48
 Re: Industrial 2000 in reply to daverd4, 10-26-2019 21:08:56
PTO could have been added after it left the factory.
Sean in PA
10-30-2019 04:20:22
The ag chassis models had the same transmission, PTO and hydraulics options available as the industrials. Most industrial models did not have a PTO or 3 point hydraulics, but they could be ordered with them. Most ag models had PTO and 3 point, but some did not, and yours is one of those.
Breakdown of your 21201 model number:
First 2 = 2000 series
First 1 = made in 1963 or later
Next 2 characters, 20 = General purpose ag chassis with adjustable front axle.
Final 1, on 1963+ tractors = 4 speed transmission without PTO or 3 point hydraulics.
daverd4
10-30-2019 07:07:22
 Re: Industrial 2000 in reply to Sean in PA, 10-30-2019 04:20:22
Thanks it has a PTO but no Hydraulics. It has a flat plate under the seat unlike my 861 and 961
Sean in PA
10-28-2019 11:30:36
21201 is the model number. If it was a light industrial the middle digit would be a 3 instead of a 2. I don't know if they even made a Heavy Duty Industrial model in the 2000 series, as I think those were only offered in the 4000 series, but if they did the middle digit would be a 4.
John in La
10-28-2019 04:44:56
Tell us if the front axle is solid or adjustable.
Reason I ask is that transmission is from a ag tractor not a light industrial.
daverd4
10-29-2019 08:36:11
 Re: Industrial 2000 in reply to John in La, 10-28-2019 04:44:56
The front axle is adjustable. Why do you say the transmission is ag curious what the difference is?
Thanks David
john in la
10-29-2019 11:17:59
 Re: Industrial 2000 in reply to daverd4, 10-29-2019 08:36:11
I was trying to see if you had a industrial tractor that has had a transmission from a ag tractor put into it or if you had a ag tractor that has been repainted industrial colors with industrial stickers.
The fact that it has a ag adjustable front end and a ag model number stamped on the transmission tells me that is a ag tractor that has been repainted.
daverd4
10-29-2019 20:51:09
 Re: Industrial 2000 in reply to john in la, 10-29-2019 11:17:59
I will take some better pic's and post of the tran's sure looks like a factory 2000 Loader Backhoe to me. No 3PT no hydraulic controls on top of the tran's like a ag tractor?
Kirk-NJ
10-27-2019 00:02:58
Ford 2000 4 cylinder with 134 gas or 144 diesel built after Aug '62 with adjustable front axle. Four speed with pto. Some of the light industrials had a one piece solid front axle Your tractor was built the last week in june 1965. Not sure what the symbol is after the serial number. This was basically the last of the 4 cyl except for maybe the offsets. They were build the square nose 3 cylinders at the same time.
daverd4
10-27-2019 06:43:49
 Re: Industrial 2000 in reply to Kirk-NJ, 10-27-2019 00:02:58
Thanks for the info. Is the bottom number the serial #? I would of thought by then they would all be 172 CI ?
Kirk-NJ
10-27-2019 07:57:55
 Re: Industrial 2000 in reply to daverd4, 10-27-2019 06:43:49
Sorry I meant the symbol after the model number, top one. Yes bottom one is serial number. The 2000 is 134 or 144D The 4000 is 172. It's possible the engine could have been changed out. Post the letters/numbers on the bottom section right side of block.
daverd4
10-27-2019 07:05:50
Copyright © 1997-2020 Yesterday's Tractor Co.
