Company Logo Shop Now
TractorLinks.com
Re: Air Cleaner Help
Destroked 450
10-26-2019 15:38:36
There is no end cap for that setup, the rubber seal on the outer filter covers the end of the canister with the wing nut holding the filter in place.
The cover you see "item #12" is for the industrial models that don't have the flip up nose piece, same cover as used on the earlier -600 series with the one piece radiator shell.
My 6610 has the same style air cleaner, install the inner filter using the nut and gasket, install the outer filter, tighten the wing nut, close the flip up nose panel and install the pre cleaner.
Bouncer
10-26-2019 17:20:06
 Re: Air Cleaner Help in reply to Destroked 450, 10-26-2019 15:38:36
If that is in fact true, it is a very bad design and that rubber seal barely covers the edge gap. However you can look up parts by serial number on NH and that cover does not mention it is row crop or industrial specific. Thanks for the info though, appreciate it!
Copyright © 1997-2020 Yesterday's Tractor Co.
