Company Logo Shop Now
TractorLinks.com
Order Ford 2000 Parts Online
Re: Ford 2000 starter problems
Mike(NEOhio)
10-26-2019 06:18:03
Start with the battery and cables. Check the charge and make sure ALL the cable connections are clean and tight.
gmcinnes
10-26-2019 06:34:50
 Re: Ford 2000 starter problems in reply to Mike(NEOhio), 10-26-2019 06:18:03
Yeah, I did the battery and cables.
Cleaned the posts and terminals, cleaned the connections at the starter. Did a load test on the battery, and I'm told it's fine. Measured no resistance on the cables, using my ohmmeter.
The symptoms seem like low current to the starter, but I don't seem how it can be, given the above.
Bern
10-26-2019 18:22:24
 Re: Ford 2000 starter problems in reply to gmcinnes, 10-26-2019 06:34:50
You don't use an ohmmeter to check for resistance in battery cables, or any cable for that matter. You test a cable by voltage drop as discussed above.
gmcinnes
10-27-2019 10:58:14
 Re: Ford 2000 starter problems in reply to Bern, 10-26-2019 18:22:24
I should have said continuity meter, which shows the resistance, but I understand, and will try the procedure you described.
Copyright © 1997-2020 Yesterday's Tractor Co.
