BambiBasher
New User
The video should speak for itself. Just after winter I was getting p/s fluid coming out of my main steering gear box. Bad seal of course. So that snowballed into replacing all the seals and bearings in the steering assembly. Only thing I didn t touch was the springs in the power control valve. New pump, rebuild front spindle bushings, newer power cylinders, replaced the p/s lines. Basically it s a whole new unit. This thing doesn t want to steer at all really. It s making noise from the steering box so idk if the control valve needs looked at or if something is put together wrong. The whole steering unit was pulled apart and laid out in the way it came apart. I m absolutely stumped with this thing. [/u]
