Company Logo Shop Now
TractorLinks.com
Order Ford 4000 Parts Online
Re: Ford 4000 gasoline 1972 running rough
mikewood869
10-25-2019 17:56:26
Is the bottom of the carb wet? The float gets stuck and I have to pull the drain plug on the bottom of the carb and with a wire or something and pock at the float.
rams2050
10-26-2019 07:25:15
 Re: Ford 4000 gasoline 1972 running rough in reply to mikewood869, 10-25-2019 17:56:26
Thank you both so much! You've given me some ideas that I can try out.
I don't really know what kind of carburetor it is but I have never replaced it and I have had it for 35 years. It just got all new spark plugs and wires two or three years ago. It had been running great until about a week ago so I'm just grasping at straws here and you have given me some things to try. Thank you.
Dean
10-26-2019 07:46:38
 Re: Ford 4000 gasoline 1972 running rough in reply to rams2050, 10-26-2019 07:25:15
Always verify that the ignition is spot on before looking to carburetion, even if your experience tells you otherwise.
"Running rough" (missing) is generally (I did not say always) caused by faulty ignition, but it is nearly impossible to diagnose such symptoms in a chat forum.
Is it flooding? Black smoke? If so, look to float level. The OEM Holley carburetor is very sensitive to float adjustment.
Does it stumble only upon tip-in (throttle up)? If so, look to the vacuum operated accelerator pump and the usually defective vacuum advance motor, which affects intake manifold vacuum.
Many folks, herein, do not like the Holley carburetor used on Ford tractors but it was a very good carburetor in it's day, and quite simple as compared to contemporary automotive carburetors. Should you decide to rebuild yours, bite the bullet and buy your overhaul kit from a CNH dealer. Insist upon the expensive genuine CNH kit rather than an aftermarket kit and pay close attention to the float level and float drop adjustments. Be certain to take both tractor SN and carburetor SN with you when you visit your CNH dealer to order your kit (they will NOT have one in stock) and insist upon speaking with an experienced parts person.
Finally, disassemble your carburetor before ordering your kit. Some (many?) Holley carburetors cannot be cost effectively overhauled due to, e.g., corrosion damage. If this is the case with your carburetor, you will need to replace it with a Zenith.
Dean
rams2050
10-26-2019 08:16:26
 Re: Ford 4000 gasoline 1972 running rough in reply to Dean, 10-26-2019 07:46:38
Thank you for all the great information And please excuse my ignorance but what is 'CNH?' Thanks, again, in advance.
Copyright © 1997-2020 Yesterday's Tractor Co.
