LarryMaine
Got my 850 Resto running this week. Big Smiles. BUT. After getting rebuilt pump primed and working smoothly, my hydraulic lift works only in Implement Position, and not at all in Constant Draft Control Position. IT and Shop manual have same explanation on how to fix. It refers to Nuday Tool NCA-502 to set correct gap between control valve land and valve housing. From the photo it looks like a simple thick go-no-go block. To make my adjustment to the turnbuckle I don't need the tool, but I do need the dimensions or thickness of this block. Does anyone have one, and can you let me know the dimensions? Also, any tips to making this adjustment as I do not want to remove the lift cover. Thanks to all as usual, Larry
