Ford Tractors Discussion Forum |
Nuday Tool NCA-502 Info Needed on Dimensions
Author |
[Modern View] |
LarryMaine
10-25-2019 10:11:08
Got my 850 Resto running this week. Big Smiles. BUT. After getting rebuilt pump primed and working smoothly, my hydraulic lift works only in Implement Position, and not at all in Constant Draft Control Position. IT and Shop manual have same explanation on how to fix. It refers to Nuday Tool NCA-502 to set correct gap between control valve land and valve housing. From the photo it looks like a simple thick go-no-go block. To make my adjustment to the turnbuckle I don't need the tool, but I do need the dimensions or thickness of this block. Does anyone have one, and can you let me know the dimensions? Also, any tips to making this adjustment as I do not want to remove the lift cover. Thanks to all as usual, Larry
LarryMaine
10-28-2019 17:15:33
Re: Nuday Tool NCA-502 Info Needed on Dimensions in reply to LarryMaine, 10-25-2019 10:11:08
For some reason my follow up comment did not show up. I thought I could do it without removing the cover because the Manual says to remove the inspection plate (the one with the dip stick) and measure the gap that way, so I assumed I could make any adjustment through the inspection plate hole. Obviously, you guys have more experience than I in this area, and I am resolved to remove the lift cover. That makes it a Winter project once I get enough Kero for the tank to heat my garage, get the gasket and O rings, put the come-along up to the rafter, etc. Of course, here in Maine, Nov. is deer hunting season, so I'm afraid I have to prioritize finding bambi over fixing the 850. Thanks all, I will first try to adjust the draft plunger.
Hobo,NC
10-25-2019 18:53:12
Try backing off the draft plunger a few turns...
The draw back is it changes the height of the lift arms when in the lower position...
markct
10-25-2019 17:28:03
If you manage to adjust it without removing the cover then you are definitely the king of Ford tractor repair! Never known anyone to be able to do that, but the good news is the cover comes off easily just be sure and have the gasket and two o rings especially on hand
Keith Williams
10-25-2019 11:28:44
The I&T manual has instructions on the dimensions to measure without those special tools. It says to remove the lift cover. Never heard anyone do it any other way. Keith
JMOR
10-25-2019 10:29:49
Quoting Removed, click Modern View to seeIf you accomplish adjustments w/o removing lift cover, don't forget to come back and tell all how you did it.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Fast Shipping! Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ] |
Home
| Forums
Copyright © 1997-2019 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
