That appears to be the wrong cluster to me. That cluster uses bi-metal gauges like an old 3000 did, rather than magnetic gauges like your original one has. I can see this because it uses a voltage stabilizer on it, the device that looks like a circuit breaker with the B and I terminal on it.
If you attempt to use this dash, your gauges will not be accurate, not even close.
