Company Logo Shop Now
TractorLinks.com
Re: 2910 Gauge Cluster Help
Destroked 450
10-23-2019 22:16:39
Looks like you have the wrong cluster.
Early 2910's used a cluster like older models, part # E5NN10849BA on this site
Later 2910's used a cluster like seen on the new --30 series, part # 83954555 on this site
What's wrong with the old cluster, if the lens is glazed over you can purchase a new replacement lens.
bouncer
10-24-2019 00:02:08
 Re: 2910 Gauge Cluster Help in reply to Destroked 450, 10-23-2019 22:16:39
It is in fact the proper cluster and it is the first one you listed. As for why I am replacing it, Iím not sure what difference it makes. However to answer your question, it is because the tach is broken.
Bern
10-24-2019 05:28:34
 Re: 2910 Gauge Cluster Help in reply to bouncer, 10-24-2019 00:02:08
That appears to be the wrong cluster to me. That cluster uses bi-metal gauges like an old 3000 did, rather than magnetic gauges like your original one has. I can see this because it uses a voltage stabilizer on it, the device that looks like a circuit breaker with the B and I terminal on it.
If you attempt to use this dash, your gauges will not be accurate, not even close.
Copyright © 1997-2020 Yesterday's Tractor Co.
