Company Logo Shop Now
Order Ford NAA Parts Online
NAA rear axle seal replacement
fixerupper
10-23-2019 16:16:04
I have a NAA in the shop that needs new rear axle seals and brakes. I have a parts manual for a NAA and also a N series shop manual that does not cover brakes GRRR.
I have two questions, first, what company sells the best shop manual for a NAA?
Second question, I want to get it apart now. The drums and hubs are off and I assume the backing plate needs to come off too. I have the six backing plate bolts out of the axle flange but the backing plate won't come loose. If it does need to come off, is it normal for it to stick to the axle and be hard to remove? I don't want to hurt anything trying to get it off. Thanks
Hobo,NC
10-23-2019 19:41:13
 Re: NAA rear axle seal replacement in reply to fixerupper, 10-23-2019 16:16:04
If they come off EZ it don't look good for the home team... Axles and hubs may be in your future.
Post on Ford 9N,2N,8n forum to get pix of what worn and good is...
I know so don't have/need pix :(..
fixerupper
10-23-2019 19:12:09
Thanks Hobo. I did some Googling but came up short. Thanks so much for the link. So I missed a step. The four nuts and two bolts are off but I need to remove some brake parts before I get to the last two bolts. This will get the project along quicker. The link mentioned loose hubs. I backed away the brakes and fairly easily removed the hubs without needing a puller. Maybe new hubs are in order too.
Hobo,NC
10-23-2019 18:36:44
John Smiths how 2
https://fordtractorcollectors.com/rear-axle-seals/
Hobo,NC
10-23-2019 18:34:11
4 nuts that go on studs and 2 bolts it should come off...
Its the same as a late 8N
Latest Ad: 990 7 foot mower conditioner john deere hay rake pto driven john deere head carrier [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
