Company Logo Shop Now
TractorLinks.com
Order Ford 3000 Parts Online
Re: Considering Weights and Mods to our Ford 3000
Sean in PA
10-23-2019 13:39:59
What exactly happens when you try to pull the heavy wagon up the ramp with the 3000? If the wheels slip then adding weight will increase the traction and may allow the 3000 to pull it up the ramp. But if the 3000's wheels do not slip and it simply can't pull the weight up the ramp then adding weight will not help.
The 3000 has a cat I 3 point hitch and the bigger 4WD tractor is more likely to have a cat II hitch, so you would need to have 2 sets of pins on your home made weight device, one set for cat I and one for cat II.
Copyright © 1997-2020 Yesterday's Tractor Co.
