Company Logo Shop Now
TractorLinks.com
Order Ford 5000 Parts Online
Ford 5000
Gerard 1702
10-23-2019 12:59:16
Hi all I have 1968 Ford 5000 that needs an engine. I have been offered an engine out of a 7000. Would this be a straight replacement would I need to change anything else as there s gonna be a jump in horsepower now running all through the tractor?
Gerard 1702
10-24-2019 07:53:53
 Re: Ford 5000 in reply to Gerard 1702, 10-23-2019 12:59:16
Great piece of information very informative sounds difficult but not impossible?
Destroked 450
10-24-2019 07:37:15
The 7000 engine is a direct bolt on but as others have said it's best to upgrade to a 7000 radiator which will fit.
The issue I see is the air cleaner system, 5000 has a oil bath air cleaner and 7000 uses a dry element (paper) air filter, all of the piping is different in order to connect the air cleaner system to the 7000's turbocharger, even the front radiator shell is different to allow for the different air cleaner.
To use the 5000's oil bath air cleaner you'll have to fab the piping.
SkipperII
10-26-2019 19:23:05
 Re: Ford 5000 in reply to Destroked 450, 10-24-2019 07:37:15
This past spring, I located a 7000 air cleaner assembly, and a new grilles shell. Using exhaust elbows and tubing, I switched a buddies' 5000 over to a dry system, so it can be done, with a little adapting. He hated the oil bath, and had bugged me for three years.
Gerard 1702
10-24-2019 07:20:12
Thanks everyone for the useful info
JK-NY
10-24-2019 05:42:42
As mentioned I would be concerned with cooling capacity. The engine should pretty much be a bolt in fit. Not sure if you can use the 7000 radiator in the 5000 too but I would be looking at options to upgrade the cooling system. If you have a good radiator shop they may be able to help you, although good radiator shops are getting rarer than hens teeth.
Sean in PA
10-24-2019 04:36:56
History of the transmission would be a factor, if it was already worn some from being run hard in the past, then running it hard with the more powerful engine may cause issues earlier than if it had an original hp engine. But even if it was never worked hard with the original engine, over working it with the 7000 engine could cause issues on its own.
Gerard 1702
10-24-2019 03:48:01
Ok thanks guys. Would the extra power only be one an issue if the tractor was been worked hard on a very frequent basis ?
Bern
10-24-2019 05:30:45
 Re: Ford 5000 in reply to Gerard 1702, 10-24-2019 03:48:01
With regards to the tranny, yes. With regards to the cooling system, it won't take long for the stock 5000 cooling system to overheat if the engine is run at full load. I'm talking minutes, not hours.
At a minimum I'd put a larger fan in it.
Ultradog MN
10-24-2019 05:22:07
I would say Bern put it best.
It's similar to putting a 172 ci engine from an 800 in place of the 134 in a 600.
They're a direct swap and the 600 would do a lot of useful work, for many years, as long as you don't lay into it hard all the time.
In the 800/600 case you'd blow the rear end, not the transmission but kaput is kaput after all.
Bern
10-23-2019 14:34:52
A 7000 has a stronger tranny and larger cooling package. Keep that in mind if you make the swap and all of a sudden start liking the extra power.
Shaun Wallace
10-23-2019 13:57:33
Direct bolt in. Tach will be driven off inj pump instead of gen if even works.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
