Company Logo Shop Now
TractorLinks.com
Order Ford 4000 Parts Online
Re: Ford 4000 Hydraulics
sotxbill
10-23-2019 07:10:12
At 1600 rpms or higher... a good pump will go up to around 2175, then pop the relief valve and then the gauge will vibrate around 1900 lbs for a 4000. 4600 would be higher, 4610 higher, again iirc.
A bad pump might go to 2175 at first when cold,, but start dropping to 1600 or even 1200 lbs after a few minutes. A really bad pump will never get close to 2175..
A glycerin filled gauge from northern tools or other places with a 1/2 iso hydraulic connector works well on tractors with quick disconnects .
https://www.ebay.com/itm/TL37-M-1-2-NPT-Thread-1-2-Ag-Hydraulic-Quick-Coupler-Poppet-Valve-Pioneer/323910004391?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D60256%26meid%3Dd465061bf10c42f1819078dd536812d1%26pid%3D100005%26rk%3D1%26rkt%3D12%26mehot%3Dpf%26sd%3D401813989675%26itm%3D323910004391%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851
https://www.ebay.com/itm/2240GXB3000-Valley-Instrument-Pressure-Gauge-Glycerin-Filled-0-3000psi/193036296979?hash=item2cf1dc2313:g:KVkAAOSw0lldSzEn
and you will need a 1/4 inch to 1/2 inch reducer bushing
https://www.ebay.com/itm/1-2-1-4-Male-to-Female-Thread-Reducer-Bushing-Pipe-Fitting-Brass-Metal-NPT/183782327823?hash=item2aca47c60f&_trkparms=ispr%3D1&enc=AQAEAAADMKvsXIZtBqdkfsZsMtzFbFsbX3WcW5fmB%2Fx7ZbaZTyexL1IIkRAVlexSUhRdI5g8cPKblYDWO7I94vK0b3yPeD02DJa3cjMw8EkQVWNothXqn3U0jbIO6yiBgilTZkiqQMXbg6a3T2IxqVPz7KrGJxh%2FsemKc4oUQ1GAg%2FuZsp5%2FOQuUL4QiVAyFdlKP1fqTfpIUTcPITr6yOoUxliCn6fT5k0dfD8awYV9FAS81SPgvzx7oRg09HKbHfMJWHDBAE1KqlhxbV9OLLIcN3fwiZnGAHjMy06BXz1nfVTUvxbIzL611cqZjF0RKHgG7BJWosVh3wJr07pExHlSBEt9X855LnnKcTNpVMwQwiz8F58QaGKgZ0%2FUNuuuJUMX48zV3Pm70fGJDTfDxOG4mZQbDmX4sFNh4N3ddRASKIFOGX1SSXE4eqqWiMV0OwcR9avTwSSFx%2BA1BDhn5YXrdWPi72EoKPe%2B0WVuOhQxzJNEdLui5aW4xVyDMHnBT9fSDE9ylzTkFhZ2y2VdPo7BjP5D6a6UaJb4xN%2BoaFlpixcQ77JRerLChgbbawIiibRt1KCXFAs0sN7nJyXR0EOyLOpk63nSHB%2FlMT%2FXJ4daYGnFwM7UtJuUknw%2BfPRucmJiqlXkiE59l%2F%2FBc%2BMWtpruPK52JLI%2BxySBFgR1fMGJUxssaCTcXH6WXBoIX3RLLOCx2hqVlSVHNIndLPKOALAaYscINA3fZlahnbIae%2BwpOw0wS34q%2FxRgdkqOZGBqtidwFl3E06LNzCW9zaxcOhJfW0WrXriE0SMHbR6uZRy4UQx8X%2F0Ym%2BImdgnQRY5SY6IhZmCjcUhB6f4sd7GTeANjfRP7FxDkUVTtQ5fzPglNrL6snSO5o5D6B%2BA2FnkCAUT9iyDcm2ZlTcvN%2FQc9iHovgMEfzTyHulXtI2S3cz8XS68WtdYWrfqlkTcelhM%2B4HPPAr66ojzyLj94bIjZDrxGRXYXwzl3YJ23RoIn8iTUyqUnBO%2B3ZwbKDAJ8jx7RCRE6x7yKrDL5yIeRIXGO%2Fe34VpnCAkV1qE6vxLAuMOmO9uGNQjv%2FSllhqSa1B8kYk%2BfSIPa6bxg%3D%3D&checksum=1837823278230a7f9c60e10d423c8420f90b8ee3ca0f
good luck.
Copyright © 1997-2020 Yesterday's Tractor Co.
