ford 1200 stuck clutch
cdv
well started my ford 1200 today 1st time in over a year clutch is stuck any tricks to free it up before I slit it thanks cdv
Tie the clutch pedal down with a bungee cord. Start it and go. Drive it around a while. Stuck clutch has happened to me several times. The last time, I was driving my Ford around in the hay field. Went across a shallow dip/ditch. This caused the tractor to bounce a little. That is when it popped loose.
