Company Logo Shop Now
TractorLinks.com
Order Ford 600 Parts Online
Re: 3600 no fuel
RM-MN
10-23-2019 03:07:41
Gravity flow from the tank should be a steady stream so look for a blockage right at the tank outlet. You will need to empty the tank, then remove the fuel shutoff at the tank. There should be a replaceable filter screen attached to the fuel shutoff valve. Clean it, blow it out with air hose, or replace it.
The tractor should run without the fuel pump but the flow when the fuel gets low will not let it have full power. The fuel pump gives it full flow until the fuel runs out.
kenbob
10-25-2019 06:55:54
 Re: 3600 no fuel in reply to RM-MN, 10-23-2019 03:07:41
IT is in the fuel pump where the blockage is.
Copyright © 1997-2020 Yesterday's Tractor Co.
