THe latest trouble with my friends recently acquired 3600 gas is after he let it run out of gas, he could not keep it running. We took the lines
apart and found some blockage Question 1. The line goes from the tank, up to the front of the block, into a fitting, back out again and then to the
carb. What is the purpose of all this? Why doesn't it go from tank direct to sediment bowl and carb? If we put air pressure on it it will blow
through. Mouth pressure going in, brings some air back out but there seems to be quite diminished. After all that we tried gravity flow gas and it
barely drips. We have never worked on a tractor this new so it has us bewildered. Thanks for any advice.
