Company Logo Shop Now
TractorLinks.com
Order Ford 801 Parts Online
801
elton fancher
10-22-2019 10:10:14
Working on 801. Won't run on rear cylinder. My gauge shows near 90 lbs compression, but 120 on front two cylinders and a little less on 3. Don't run right on 3 either. Could my gauge be wrong? How much should they have. Distributer looks good, plugs fire every time.
338ftw
10-25-2019 10:21:24
 Re: 801 in reply to elton fancher, 10-22-2019 10:10:14
lmao
elton fancher
10-25-2019 18:13:46
 Re: 801 in reply to 338ftw, 10-25-2019 10:21:24
Well I should not respond to this, but your lmao makes it easy. When someone comes on here and asks for honest advice and gets a smartxxx reply that should be seen as a failure or at least a weakness in that person who chooses to embarrass himself buy seemingly implying that the fellow who ask for advice must be stupid then you need to think how bad that really is. But if you condone it ok. I would say that I believe if someone does not have relevant advice maybe they should be cool.
JMOR
10-23-2019 15:32:32
Quoting Removed, click Modern View to seeWhy the belief? Where did it blow to? Water in oil, oil in water, bubbles in radiator, compression escaping to outside between head & block? Where?
elton fancher
10-23-2019 15:54:37
 Re: 801 in reply to JMOR, 10-23-2019 15:32:32
No water in oil, nothing seems to be happening in radiator. Cannot see much compression loss any where. Tractor will hit on no. 3 and 4 cold, does not take long before you can pull those wires with no effect on engine. You can cross them and get nothing. Pull no. 1 or 2 and it will die. However no. 4 will show 90 lbs cold but drop to 60 warm. No. 1 and 2 will consistently show 120, no. 3 will drop to about 80 warm and 110 cold. Puzzling.
JMOR
10-23-2019 10:13:38
Quoting Removed, click Modern View to seeI have been reading these forums for many years & have gathered that at the first sign of any tractor problem, one should jerk the head off, even if a flat tire!
showcrop
10-23-2019 05:29:40
Elton, What does "looks good" mean to you?
elton fancher
10-23-2019 15:12:25
 Re: 801 in reply to showcrop, 10-23-2019 05:29:40
Valves opening with a little slack in the rockers when closed. Oiling, and cannot see any compression loss on top. I will gauge the valves when I get time. I believe it possible that head gasket blown.
ernied
10-22-2019 11:09:55
It should have 120 at sea level with a calibrated gauge. It will run on 60, but difficult to start on starter motor. If the exhaust note is not lisping I would be inclined to suspect a caked intake valve restricting incoming charge.
elton fancher
10-22-2019 11:30:34
 Re: 801 in reply to ernied, 10-22-2019 11:09:55
Guess I will pull the head. Tried all else I could think of.
Bob
10-22-2019 10:36:05
Mite not hurt to pull the valve cover and see if the #4 valves are operating properly 9pushrods in place, not bent, have "lift" and setting is correct, if all that seems OK, do a leakdown test to see where the compression is going.
elton fancher
10-22-2019 10:59:03
 Re: 801 in reply to Bob, 10-22-2019 10:36:05
Had cover off. Looks good. Checked compression with all 4 plugs out. Kinda got me puzzled.
Bob
10-22-2019 11:38:23
 Re: 801 in reply to elton fancher, 10-22-2019 10:59:03
As I said verify valve left, and do a leakdown test.
Copyright © 1997-2020 Yesterday's Tractor Co.
