Aaronriley08
New User
Hello,
I have a 1965 ford 4000 with the gear driven pump. The lift is generally unresponsive for a few seconds and then it will go up with no problems and stays up fine while Im running it. I dont know if it stays up over night I normally put it down when Im done using it. The other day I hooked a work saver post driver to it (it has the single remote valve on it) when you turn on the hydraulics to the post driver it drops the lift to the ground and the driver doesnt work. I know its pushing fluid but Im afraid the pumps just worn out. Anyhow, before I go wild and go down the parts chasing path I wanted to see if anyone else had any ideas as to what my problem is. Any ideas would be greatly appreciated! Thanks!
