Company Logo Shop Now
TractorLinks.com
Order Ford 6000 Parts Online
Re: 6000 SOS input
Dieseltech
10-21-2019 13:41:00
I do have access to welders, mill and lathe. Not sure what tensile strength of wire welding is, maybe 6xxx or 7xxx stick is stronger. Did not count the splines of the best shaft, but looks to me a more course spline count would last longer.
Bern
10-21-2019 14:12:51
 Re: 6000 SOS input in reply to Dieseltech, 10-21-2019 13:41:00
A coarse spline is in fact stronger - I recall reading a service bulletin on the subject when Ford went to a coarse spline on the later SOS transmissions. They did the same on the input shaft of the later 8-speed crashboxes.
That said, lubrication makes a big difference. Notice how the splines are the same size on the other end of the shaft, and you never see any wear there. I always use a heavy duty spline lube on the torque limiting clutch splines and mating input shaft when putting a SOS trans back together.
Dieseltech
10-21-2019 16:43:34
 Re: 6000 SOS input in reply to Bern, 10-21-2019 14:12:51
Did the later SOS input shafts have a larger diameter too? Looking at the three I have apart now, they sure look smaller than I'd like to see when compared to other tractor input shaft sizes.
Bern
10-21-2019 19:13:36
 Re: 6000 SOS input in reply to Dieseltech, 10-21-2019 16:43:34
They didn't change the diameter, only the spline count and angle. I remember reading a service bulletin about it. I thought maybe Fordfarmer could look it up for us with the stack of bulletins he just bought, but according to the parts book it's a 1968 bulletin.
Copyright © 1997-2020 Yesterday's Tractor Co.
