Company Logo Shop Now
TractorLinks.com
Re: oil change alternative to NH mc134
showcrop
10-21-2019 06:44:54
What is good to use depends on how you use your tractors. Neither of them have wet brakes or clutch packs, both of which would necessitate the use of universal transmission hydraulic fluid which has the additives necessary for the clutches and brakes. Oil with additives will absorb moisture from condensation much more readily than the cheap oils. If you use the UTF and work your tractors hard enough and frequently enough to get the oil hot enough to drive the moisture out, then it is OK to use the expensive oil. If not you need to check your oil regularly for moisture which makes it look milky. The moisture in milky oil is bad for the components. When you get moisture you should change the oil. If you use the cheaper oils without the additives the moisture won't be absorbed and you can eliminate it by simply loosening the drain plugs and draining the water out.
Copyright © 1997-2020 Yesterday's Tractor Co.
