Company Logo Shop Now
Ford 641 knocking
jo.knight@fwcs.k12.in.us
10-20-2019 14:03:06
I have a ford 641. I was grading the lane like I do often. The tractor started to knock so hard the entire trActor shook and died. I towed it back to the shed. It will turn over but it knocks so bad. It sounds like the knock is under the hood, but it shook so hard it even shook the seat. Any ideas what is going on with it?
bobwhitecar
10-21-2019 14:03:31
 Re: Ford 641 knocking in reply to jo.knight@fwcs.k12.in.us, 10-20-2019 14:03:06
I am not that far away if you need it worked on
bobwhitecar
10-21-2019 14:00:25
drop the oil pan and look at the rods
showcrop
10-21-2019 05:50:41
I would be on the hunt for a used motor, either a 134 or a 172. If you share your location you can get suggestions on where to look.
10-21-2019 06:50:29
 Re: Ford 641 knocking in reply to showcrop, 10-21-2019 05:50:41
Fort Wayne, IN
CTPhil
10-21-2019 05:21:34
Unfortunately the only thing to do is start taking it apart and see what's broken :(
docmirror
10-20-2019 14:45:59
If it shakes the tractor, it's either a broken crankshaft, or at the flywheel.
10-20-2019 14:49:05
 Re: Ford 641 knocking in reply to docmirror, 10-20-2019 14:45:59
Thanks so Much.
CTPhil
10-20-2019 14:38:38
Last time I had that it was a spun rod bearing. I don't know if that's your issue but your description is not of something that's an easy fix.
10-20-2019 14:43:05
 Re: Ford 641 knocking in reply to CTPhil, 10-20-2019 14:38:38
Iím sure it is an expensive fix whatever it is. Thanks for your response.
Copyright © 1997-2020 Yesterday's Tractor Co.
