Help Identifying Ford Tractor Please
johnfkuch
New User
Helping out a neighbor with his tractor and need to find out info to buy new injector lines. tractor c765112 model cu414c unit 5j02b engine 6f20a 3 cyl diesel. thanks for your help.
A CU414C is a 340B industrial tractor
CU4 = 340B 1984-88
1 = Diesel
4 = Ind. 540 rpm
C = 8x2 speed manual (4x1 + hi/low)
interestingly your given "unit" number 5J02B would be Sept 2,1985 second shift as the tractor assembly date, the engine number given 6F20A would be June 20,1986 first shift
might be a good Idea to recheck all the numbers
the C765 serial number is from 1986 also
