I recently replaced rings, head gasket and other gaskets as needed. Top compression rings on 2 pistons were broken so it needed a little work. It still starts hard with alot of white smoke. Once it's running it runs rough like not firing on all cylinders. After it warms up it runs out real good. When i pull the injectors they are real black and real sooty.
Do i need new injectors?
Anybody have any suggestions on this problem. I'm open to try anything.
Wondering also on this Simms inline pump if there is any slight timing adjustment. It looks fixed in its position
